It is currently Tue Aug 12, 2025 1:51 am
 Post subject: I need your measurements
PostPosted: Tue Mar 15, 2016 10:10 am
Last Name: Ensor
City: Springfield
State: Missouri
I am needing to collect some measurements. I am needing to know the hole spacing on different laminate trimmers and mini-routers bases(no full sized routers needed). What do you think OLF, can you help me out?
Please denote the brand and model as well as the measurement(s) for your spacing. Thanks.
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Tue Mar 15, 2016 10:38 am
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Hi Chris, what specs are you wanting?
I have 4 or 5 different ones I could measure.
PostPosted: Tue Mar 15, 2016 11:41 am
Last Name: Ensor
City: Springfield
State: Missouri
I am needing the hole spacing of the screws that hold the plastic plate to the base of the trimmer/router.
PostPosted: Tue Mar 15, 2016 11:44 am
Perhaps you could list what you already have so there's no duplication.
I have a Porter Cable 3102 and 7301, and a Makita 3709.
PostPosted: Tue Mar 15, 2016 2:48 pm
I've got bosch colt base plate plans drawn up in cad if you want them.
PostPosted: Tue Mar 15, 2016 3:13 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Rigid laminate trimmer model #R2401. Hole spacing measures at 2 3/16" or 55mm, square layout.
Alex
PostPosted: Tue Mar 15, 2016 5:55 pm
Last Name: McDonald
Bosch Colt pr10 3" x 2.72"
Dewalt dwp 611 2.42" square, but there are 4 more holes asymetrically placed. all holes are at 1.73" radius c-c from the center of the collet.
I can measure the PC when I get home.
PostPosted: Tue Mar 15, 2016 9:29 pm
Last Name: Ensor
City: Springfield
State: Missouri
Thanks everybody. Keep them coming. I need as many as possible.
PostPosted: Wed Mar 16, 2016 3:42 pm
Makita RT0700C
I make it 54 mm x 45 mm, long side towards the catch.
PostPosted: Wed Mar 16, 2016 9:42 pm
Last Name: McDonald
PC7301
As you can see, multiple holes
The plastic base mounts to the 3 lower holes in the pic.
2-11/32" across l-r
-21/32 from l or right to the lower
On the boss with the 2 holes the upper one is the bottom end of the depth adjuster.
The other on that boss and the one to the right are 1" apart.
The upper 2 are 2-1/16" apart.
PostPosted: Sat Mar 19, 2016 12:17 am
Last Name: Lee
City: Albany Creek
State: QLD
Zip/Postal Code: 4035
Colin North wrote:
Makita RT0700C
My Makita RTO700C has a trapezoid base pattern , one side 54 mm and the side parallel to this 56 mm, each of these spaced by 45 mm.
From collet centre to holes 56 mm apart the radius is 38.25 mm.
From collet centre to the 45 mm spaced holes the radius is 33 mm
Rebel tools REB500T has square base hole pattern 58 mm
Users browsing this forum: TimAllen and 51 guests
